WP-34s 2.0 Manual correction? Message #11 Posted by gene wright on 8 June 2011, 7:24 p.m., in response to message #10 by Paul Dale
Page 58 of 81: In the h CAT catalog description, it specifies 0 - 2 as the flash segments. Isn't this 0-3 now?
At least, 0-2 on page 58 seems inconsistent with the description on page 12 of 81. I'm thinking I'm either confused (possibly) or that page 58 should say 0-3.
Also on page 12 of 81, it references segments 2, 1 and 0 in that order. Should that be 3, 2, 1, and 0? Paragraph on page 12 is below.
"Else, i.e. if xy is an alpha label of up to three characters of arbitrary case, searching will start at program step 000 and cover the entire memory in the sequence RAM, flash segment 2, flash 1, flash 0, and XROM, independent of the position of the program pointer."
And, again, for the record, I consider the flash "pages" 1, 2, and 3 and their ability to be called as subroutines or executed in place as perhaps one of the most substantial features of the entire WP 34s!
Edited: 8 June 2011, 10:24 p.m.
