Re: HP-41 Repair Parts Message #2 Posted by Geoff Quickfall on 1 June 2011, 1:46 p.m., in response to message #1 by aj04062
Both projects are worthy but lets see if they have been done before as your expense may not outway the benefits from and easy repair:
Reinforcing the rear shell screw holes can be accomplished easily with spare plastic pieces:
I can't find the original article I posted but the above photos show the main points. I am only posting this as this is an extremely easy fix and cheap versus a prefab piece and associated costs. Of course, I may have misinterpreted your intent. If so, sorry.
As far as the ribbon battery contact idea, have you seen:
Deigo Diaz site
Is this the ribbon contact you are refering to. I have used three of these and they are fantastic!
Hope this helps and again if I misinterpreted your intent I apologize ahead of time.
Cheers, Geoff
Edited: 1 June 2011, 1:50 p.m.
