Re: HP9800e emulator Message #6 Posted by Eric Smith on 24 May 2011, 1:12 a.m., in response to message #5 by Tim
Well, if you had download the binary ZIP file rather than the source ZIP file, you wouldn't have to do anything.
If you really want to tough it out with the source ZIP file, you need to compile everything. It's not entirely obvious what the procedure is, so if I wanted to do it, I'd look at the jar file in the binary ZIP file to see how it is organized, compile the source files, and package them into a jar similar to the one in the source ZIP file. This seems tedious and error-prone, so I'm not going to try to do it myself unless I decide that I want to modify the source code.
Edited: 24 May 2011, 1:14 a.m.
