Jeff has noticed that the flash file for the most recent release of wp34s is shorter than before.
Before you ask more questions, here is the file doc/flash.txt which explains it.
Commands to handle the flash memory on the real calculator
Hold down ON (EXIT) and press one of the following keys:
STO - Backup: This creates a copy of the RAM in flash memory.
RCL - Restore: This restores a previously created backup.
S - SAM-BA: Clears the GPNVM1 bit and turns the calculator off.
S is on the '6' key.
ATTENTION: You can now only boot into SAM-BA mode!
Without the SAM-BA software and the cable, you're lost!
These ON key combinations have to be pressed twice in a row without
releasing the ON key to be executed.
Do an ON+STO before you want to flash a new release! After flashing,
your backup should still be in place if you didn't press the ERASE
button on the cable but used ON+S instead to get into SAM-BA boot mode.
There are additional commands in the program functions catalogue:
PSTO n Store program in region n. n is 0 or 1. A region is a
block of flash memory that can hold a copy of the
user program area. In a later version, alphanumeric
labels in flash can be called with XEQ. This allows
creation of libraries.
PRCL n Restore region n to the program area where data can be edited.
P<> n Swap the current program with the contents of region n.
How to transfer data between the calculator and your PC
The whole RAM is saved to address 0x11F800 (relative address 0x1F800)
with ON+STO. This can be copied to your PC or loaded from it.
1. From calculator to PC
a) Do an ON+STO, then ON+S, then RESET with the cable connected.
b) Press ON once and start SAM-BA on the PC. It should connect.
c) Set the start address to 0x11F800 and the size to 0x800
d) Enter a file name in the receive field.
e) You can now receive the file with SAM-BA.
f) Move it under the name wp34s.dat into your emulator directory.
g) The emulator should accept the file. Your registers and programs
will than be in place.
h) To get your calculator back in business, start the "Boot from flash"
script in SAM-BA, the same procedure you should know from flashing
the firmware.
i) Power the calculator up and perform a restore with ON+RCL. The
latest version does the restore automatically when RAM is not
valid.
2. From PC to calculator
a) Perform steps (a) to (c) from above. No need to set the size.
b) Point SAM-BA to your wp34s.dat file from the emulator.
c) You can now send the short file with SAM-BA.
d) Perform steps (h) and (i) from above.
The program regions accessible with the commands PSTO, PRCL and P<> are
stored at addresses 0x11F000 and 0x11F400 respectively and have a length
of 0x400 (1 KB) each. The emulator creates files wp32s-#.dat, # being the
region number. You can handle these files the same way as the complete
state file from the emulator. The regions have identical formatting and
can be swapped by copying their data to the "wrong" place. The backup
area is formatted differently.
If you want to get your emulator data into the calculator in one go,
do the following in Windows:
C:\wp34s>copy /b calc.bin+wp34s-0.dat+wp34s-1.dat+wp34s.dat calc-full.bin
The resulting file can be programmed into flash and all data is readily
available.
