Cell leakage in my 48S Message #1 Posted by Palmer O. Hanson, Jr. on 14 May 2011, 11:41 a.m.
I left the cells in my 48S longer than I should have. One of the cells leaked. The leakage got into the foam that provides the spring for the cell contacts. The leakage dissolved (if that is the correct word) the adhesive that attached the cell contacts to the foam. I have cleaned the compartment and have demonstrated that the calculator still works by simply holding the contact against the foam while inserting the cells.
I think that some of the leakage is still in the foam. How can I remove the leakage safely? What adhesive should I use to attach the contact to the foam? If I replace the foam where do I find foam that does not deteriorate in a few years?
Separate subject: If you wonder why H-P doesn't always implement your latest good idea I suggest that you read the article "Creation Myth" in the May 16 issue of The New Yorker.
