HP 10bii+ "soft" reset Message #1 Posted by Jim Yohe on 13 May 2011, 1:34 a.m.
When I try to do a full clear memory and reset of calculator modes using the steps outlined on page 38 of the User Guide (hold downONand press bothNandPVbuttons, then release) it doesn't come back with the All Clear message. What might I be missing or is this a bug?
Re: HP 10bii+ "soft" reset Message #2 Posted by Marcus von Cube, Germany on 13 May 2011, 2:10 a.m., in response to message #1 by Jim Yohe
Have you tried turning the calc off, pressing and holding N+PV and then turning it on with the ON key? Maybe the sequence is only checked at power on.
Re: HP 10bii+ "soft" reset Message #3 Posted by Jim Yohe on 13 May 2011, 2:12 a.m., in response to message #2 by Marcus von Cube, Germany
No but I just discovered that page 38 should have referenced the FV key and not the PV key. It's properly listed on page 164 under "Erasing the calculator's memory".
Re: HP 10bii+ "soft" reset Message #4 Posted by Tim Wessman on 13 May 2011, 2:32 a.m., in response to message #3 by Jim Yohe
Oops. :-(
Internally though, just doing the C ALL does the same thing.
