HP Forum Archive 20
Alternate wp34s Keyboard Arrangement?
Message #1 Posted by Jeff O. on 28 Apr 2011, 10:21 a.m.
I have yet to cut an overlay or otherwise attempt to re-label my 30b keys or keyboard for wp34s. I try to remember some function locations and keep a printed copy of the keyboard layout handy for reference. One thing that I keep doing is scrolling up when I meant to scroll down, or wondering why the display says “XEQ _ _” when I wanted to scroll up. This is of course due to the fact that the up/down scroll arrows of the wp34s keyboard arrangement are moved down one key from the up/down arrow keys on the 30b keyboard. I guess it is hard for my brain to remember to not press the keys labeled for the function I want to do since they are so close to the functional locations of the wp34s key arrangement. (Maybe sort of like when you see the word “yellow” printed in red and are asked what color the letters are.) So I found myself wishing that in this case, the wp34s primary functions could have been assigned to the keys on the 30b keyboard with the proper labels. This made me wonder if there were other “opportunities” for matching the wp34s functions to the keys with the proper label on the 30b keyboard. I came up with two more: RCL and +/-. (I considered x<>y and Rv, but in my opinion the 30b labels for these functions are not worth retaining.) Based on the above, I came up with the arrangement depicted below for the wp34s keyboard. I tried to keep it as close as possible to Walter’s arrangement. It would allow 20 of the standard primary key labels to be re-used, 21 if we can live with INPUT instead of ENTER, vs. 16 (or 17) for the current arrangement. Of course, in a perfect world, the key assignments for all functions could go in their absolute optimum locations without regard to the standard 20b/30b labeling, because some good solution to label the keyboard and re-label the keys will be developed. But until we get to that situation, perhaps something like the below could make it easier to use.
I did present my ideas privately to Walter prior to posting here. He noted (among other things) that he felt that EXIT and XEQ should not be adjacent and that in general if the hardware cannot be used as-is, then the layout should be controlled by ergonomic and/or logic reasons. I can certainly see his point, and as the developers, he, Paul and Marcus can do whatever they feel is best. With that said, I guess I feel that my changes are relatively mild, (and Walter said that I was free to propose anything I want) so I thought I would go ahead and present it and see what others might think. My guess is that it is relatively trivial for Marcus to assign the functions to the key locations, so perhaps he could create a version with this change for people to try out. But if everyone thinks that it is pointless, then, as Emily Litella used to say, “never mind.”
Jeff
Re: Alternate wp34s Keyboard Arrangement?
Message #2 Posted by gene wright on 28 Apr 2011, 10:37 a.m.,
in response to message #1 by Jeff O.
This arrangement looks good to me and I would like to try it out.
I too have had trouble with the placement of the arrow keys compared to the default 20b/30b locations.
Why make something difficult when there are just as good and easy alternatives?
I have other thoughts, but I will not share them yet.
Message #3 Posted by gene wright on 28 Apr 2011, 10:38 a.m.,
in response to message #2 by gene wright
This is my preferred version of the standard overlay. I had it tweaked in photoshop to improve contrast and readability, IMO.
Message #4 Posted by Walter B on 28 Apr 2011, 12:19 p.m.,
in response to message #3 by gene wright
Gene, I see your points. Just for comparison, the following is what's in the repository since build 757 (Tuesday morning your time):
Walter
Edited: 28 Apr 2011, 12:20 p.m.
Message #5 Posted by gene wright on 28 Apr 2011, 1:41 p.m.,
in response to message #4 by Walter B
That is certainly better, but a printed overlay looks better (IMO), when the back is totally black.
Also, the yellow and blue shifted symbols are not as easily read off the keyboard unless brightened as in the overlay after it was "photoshopped".
And, I have also found that the shift keys read better when they are the full color.
And, the red letters are difficult to read unless you are in very bright light.
Again, all IMO.
So, for now, I will continue to modify the overlay file and make these changes.
Message #6 Posted by Walter B on 29 Apr 2011, 9:14 a.m.,
in response to message #5 by gene wright
Enjoy, whatever "the overlay file" may be!
Updated layout and overlay
Message #7 Posted by Walter B on 1 May 2011, 5:24 a.m.,
For those interested in, there is an updated layout for the WP34S Windows emulator. And in that course also the overlay was updated - well, actually it was done vice versa, but who cares ;-)
Enjoy,
Walter
Updated overlay
Message #8 Posted by Walter B on 6 May 2011, 3:06 a.m.,
in response to message #7 by Walter B
There's an update available for prints on whatever media you want to try:
It is less sharp than the emulator skin, thus better for many color printers out there IMO.
Walter
Message #9 Posted by Marcus von Cube, Germany on 28 Apr 2011, 11:59 a.m.,
It would need an internal remap because the reference implementation shall not be changed. Internally, all keys are addressed by codes of the form K_rc, r and c being row and column. Shuffling keys will affect many places of the code if done natively.
I can, of course, add a conditional remapping but this will not change the key codes returned by KEY?, that is "f" will still return 9, not 6.
Message #10 Posted by Jeff O. on 28 Apr 2011, 1:11 p.m.,
in response to message #9 by Marcus von Cube, Germany
Sounds like it is more work than I thought, although I could certainly live with KEY? returning the "original" location. Only try it if it is something you want to do.
Edited: 5 May 2011, 7:46 a.m.
Message #11 Posted by Walter B on 28 Apr 2011, 1:15 p.m.,
Jeff,
Thanks for presenting your proposal. It can be made this way for sure. Just allow four humble remarks:
  • SW-wise, it seems to be not as trivial as you thought.
  • Since you state it shall be a transitional solution, I doubt it's worth the hassle.
  • It breaks a number of groups you may have not recognized: +/- and NOT, H.MS and DEG, ! and COMB and PERM, and especially the stack and memory group with STO, RCL, Rv, ENTER, x<>y, +/-, and E. The latter has a long tradition and - as Karl Schneider would say - is carefully arranged and well thought out.
  • How about simply using the overlay with flaps and forgetting the old 20/30b labels? Saves extra work and reduces costs d:-)
Walter
Message #12 Posted by Jeff O. on 28 Apr 2011, 9:31 p.m.,
in response to message #11 by Walter B
It breaks a number of groups you may have not recognized: +/- and NOT, H.MS and DEG, ! and COMB and PERM...
Yes, I guess I did not pay close attention to those. Most could be set right, I think (except +/- and NOT, which I can sort of see, but could do without.)
...and especially the stack and memory group with STO, RCL, Rv, ENTER, x<>y, +/-, and E. The latter has a long tradition and - as Karl Schneider would say - is carefully arranged and well thought out.
I see that your arrangement matches the 32S and 42S, but if you look at other models, these functions have moved around quite a bit. My proposal keeps them grouped petty closely, I think.
I'd love to use the overlay with flaps - where can I get one :) In any case, my concept did not get much traction, so, we move on.
Edited: 28 Apr 2011, 9:53 p.m.
Message #13 Posted by htom trites jr on 29 Apr 2011, 12:22 p.m.,
I think of x<>y, R^, Rv, and LastX as a "group" that works on the stack, with x<>mem and its buddies as being part of the STO/RCL group, and have always wondered why R^, Rv and LastX were not shifts of x<>y. And (while I'm whining) isn't there a LastY? I should really go read the manual, and will.
Message #14 Posted by Marcus von Cube, Germany on 29 Apr 2011, 12:46 p.m.,
in response to message #13 by htom trites jr
You can RCL Y but it's not saved as part of an operation such as X is to LastX (L). We would need a Last Stack command for a complete undo. Being short of battery backed up memory gets in the way here.
Message #15 Posted by Walter B on 29 Apr 2011, 1:27 p.m.,
... have always wondered why R^, Rv and LastX were not shifts of x<>y.
Many forumers will cry if/when Rv would become a shifted function {;-) I don't use it as much, and I can even live without R^ easily, but these two functions have very true friends here.
Concerning LASTx: if you did execute a complex operation (i.e. an operation on complex numbers) then CLASTx will recall both components of the complex argument, i.e. x and y. Else no way.
And yes, some reading may help d;-)
Walter
Message #16 Posted by htom trites jr on 29 Apr 2011, 5:11 p.m.,
in response to message #15 by Walter B
The manual is very impressive. It's going to take a couple of hours, and I probably won't get to it until Sunday afternoon.
I understand the love of R^ and Rv. I'd prefer both X<>Y, R^, and Rv to be on keytops, myself, but there are so few of them (STO and RCL make more sense to me as shifted, they're used less from the keyboard) ... LastX and LastY should be shifts of ENTER, maybe, in some ideal world, along with LastEntry (which would be like LastX, but it reaches back in history to the LastX that was directly entered.)
Anyway, off to read more. Didn't mean to sound critical. FORTH may have corrupted my brain.
Edited: 29 Apr 2011, 5:12 p.m.
Message #17 Posted by Paul Dale on 28 Apr 2011, 6:34 p.m.,
I experienced these problems when I first flashed the hardware. With the overlay in place, they all disappeared. Don't let the existing decals trick your mind -- get a permanent marker and obscure the errant labels :-)
- Pauli
