Re: free42 runs on Curtis KLU LT8025?? Message #3 Posted by Thomas Okken on 21 Apr 2011, 2:59 p.m., in response to message #1 by Mike Reed
I believe that model has a resistive touchscreen... I once had the opportunity to play with an Archos 5, which has a resistive touchscreen as well, and I didn't like it. I find the capacitive ones *much* nicer to use -- you only have to touch the capacitive ones, while the resistive ones require pressure. YMMV, of course, but I'd recommend trying one to make sure that that is something you can live with.
(Regarding Free42 compatibility: I can't promise that Free42 will run on the LT8025, but I haven't received any reports of Free42 not working on any Android >= 1.5 device so far, so the odds appear to be good. There are one or two where the skins don't get scaled properly... Best thing to do is to try before you buy, if Free42 compatibility is a must for you.)
Edited: 21 Apr 2011, 3:04 p.m.
