Repairing a cracked Spice case Message #1 Posted by Jeff Kearns on 19 Apr 2011, 12:47 p.m.
Hi everyone,
I just received a much anticipated 'Perfect Condition - Like New' HP 34C that is anything but...
It has a cracked case (1.5 cm hairline crack) on the lower edge of the battery compartment and the case is separated above one of the screws. Needless to say, the battery door does not stay on. Despite getting pictures and trying to ensure the state of the calculator, one can never be guaranteed that the unit will arrive as advertized.
The front face is in decent shape at least.
I know a good technique for separating the case halves on a Spice based on Spice Repair and have successfully separated the cases of my 32E and 33E in this manner.
My question is: Can I successfully repair the case cracks from the underside (to hide any residue) with a special glue made for adhering plastic to plastic? Will it resist the outward pressure of the battery? Which glue is recommended?
Geoff: When can I get a copy of your book??
Thanks,
Jeff Kearns
Edited: 19 Apr 2011, 10:40 p.m. after one or more responses were posted
