Re: Angular modes (another poll) Message #11 Posted by Gerson W. Barbosa on 17 Apr 2011, 2:33 p.m., in response to message #1 by Walter B
However the most useful conversions (that is, keeping the current mode) one would like to do from the keyboard , D>R and R>D, require at least five keystrokes each:
D->R: h X.FCN -> ^ ENTER
R->D: h X.FCN 6 ^ ENTER
Why not define shortcuts for them?
D->R: -> 5
R->D: -> D
Furthermore, since simultaneous conversions and changes of mode is not a concern to you, why not save two positions by using cyclic angle mode switching as Pauli has suggested? The blue GRAD under Rv could be replaced with DRG so our table now would be:
Assumed input Operation Output Shortcut
decimal value in any ang. mode D>R radians, ang. mode as before -> 5
decimal value in any ang. mode R>D degrees, ang. mode as before -> D
decimal value in any ang. mode DRG unchanged, angle mode
annunciators changed cyclically
from ...360 to RAD to G...
decimal value in degrees >DRG radians, ang. mode set to RAD -> Rv |
>DRG grads, ang. mode set to GRAD -> Rv | cyclically
>DRG degree, ang. mode set to DEG -> Rv |
Of course DRG and ->DRG could not be programmable commands.
The drawback would be another poll for choosing the functions that should occupy the free positions.
Gerson.
