HP Forum Archive 20
OT: Help with Logic Dart AC adapter
Message #1 Posted by Donald Williams on 18 Mar 2011, 9:54 p.m.
I think there may be a few forum members who have access to the HP LogicDart logic probe instrument. I have one which I have recently been using extensively. I would like to ditch the battery mode of operation and go to an AC adapter. Apparently I have put my AC adapter (9100-5557)in such a safe location, that now I cannot find it. The LogicDart owners manual has no description or spec for the AC adapter. On the rear of the unit it states 12V at 0.1 amp , which seems quite reasonable. There is no mention of AC or DC. It is the diagram of the contacts that bothers me. This drawing indicates the center pin as a negative contact and the outer shell as the positive contact, which at least suggests a -12V DC supply which is not a conventional approach but possible. That is not something that I would expect.
I just don't want to connect -12V DC to the unit and accidentally damage the instrument. As far as I can determine HP never released a service manual for this device, therefore I do not know if it is reverse polarity protected. I suppose it is even possible that the device needs 12V AC. I just don't have enough information.
Does anyone on the forum have that AC adapter that they could measure and confirm the contact polarity? Does anyone have a LogicDart with that same diagram on the top rear?
Any information that anyone can provide is really appreciated.
Re: OT: Help with Logic Dart AC adapter
Message #2 Posted by Eric Smith on 19 Mar 2011, 12:02 a.m.,
in response to message #1 by Donald Williams
I'm looking at a 9100-5557 right now. It is marked 12V DC 150 mA, tip (center) negative, ring (sleeve) positive.
The applied voltage isn't positive or negative; that has no meaning without a common reference. In other words, you don't have to find a -12VDC supply, as a +12VDC supply will work perfectly well. The requirement is simply that the tip be at a 12V lower potential than the ring. 0V tip and +12V ring would work fine, or -12V tip and 0V ring, or -6V tip and +6V ring.
Of course, this supply should be electrically isolated from the circuit you're testing with the LogicDart; with a wall wart this will generally be the case.
Message #3 Posted by Donald Williams on 19 Mar 2011, 12:33 a.m.,
in response to message #2 by Eric Smith
Eric
Thanks very much for the info. You have confirmed the diagram.
I understand, that of course, everything is relative to the reference, but I thought it odd that the center pin would be the reference. That is a little unconventional in my experience, but no reason why it should not work.
Now I can strap it to a bench supply and leave it running full time. I was getting annoyed by the automatic turn off after 5 minutes. I cancelled the turn off in system settings and of course 2 nights in a row forgot to tun it off manually. Now I can quit wasting batteries and just run it off a bench supply.
The information available from the members of this forum, once again, proves invaluable.
Thanks.
Message #4 Posted by Eric Smith on 19 Mar 2011, 5:40 a.m.,
in response to message #3 by Donald Williams
I wish the LogicDart had been more commercially successful, so that I could buy the new Agilent LogicDart II now.
Message #5 Posted by Donald Williams on 19 Mar 2011, 10:20 a.m.,
in response to message #4 by Eric Smith
Agreed. It is one of the handiest little gadgets I have ever owned. It would have been great to see it evolve over time. Somehow I got the impression it was not developed in house. I was always interested in the design of the unit but could never locate any schematics. I think that the $800.00 initial price was what killed it. At about half that it would have been wildly successful.
Message #6 Posted by Eric Smith on 19 Mar 2011, 4:16 p.m.,
in response to message #5 by Donald Williams
Actually it was developed in-house at HP, and some of the people involved were from the calculator division. Eric Vogel of HP gave a presentation to the Philadelphia club on June 5, 1997. Jake Schwartz has information and photos here.
Message #7 Posted by Donald Williams on 19 Mar 2011, 9:53 p.m.,
in response to message #6 by Eric Smith
Interesting| My assumption was based on the lack of documentation. Usually HP eventually releases documentation after an instrument became obsolete and the warranty period expired. Not so with this instrument. I just assumed they didn't possess the doc's. If they exist, I cannot find them. I may try to get that video.
Message #8 Posted by Eric Smith on 19 Mar 2011, 10:22 p.m.,
in response to message #7 by Donald Williams
In the 1990s HP moved toward keeping the innards of some test instruments secret, as had been done from the outset with calculators.
Message #9 Posted by hpnut on 19 Mar 2011, 6:32 a.m.,
Hi Donald,
I am not sure if the Agilent page Logic Dart User's Guide can help you.
http://www.home.agilent.com/agilent/facet.jspx?cc=MY&lc=eng&k=logic+dart&sm=g
hpnut in Malaysia
Message #10 Posted by Donald Williams on 19 Mar 2011, 10:22 a.m.,
in response to message #9 by hpnut
Thanks for the info. I do have the manual but the manual gives no details on the AC adapter. Eric has provided the details I need so all is good.
