HP Forum Archive 20
HP-41CV Display
Message #1 Posted by aj04062 on 28 Feb 2011, 10:41 p.m.
I just got a CV that seems to be acting funny.
When I first put the batteries in, it didn't seem to come on unless I would reset [on] <=.
Then after repeatedly pressing on it now seems to be alive.
What would cause the display to light up 1/2 a second after pressing on? Is this normal? The CX I have doesn't seem to have this lag.
Also, as I ever so slightly press the on-user-prgm-alpha buttons, the LCD will fade in and out.
Re: HP-41CV Display
Message #2 Posted by Diego Diaz on 1 Mar 2011, 9:29 a.m.,
in response to message #1 by aj04062
Hi there,
I'll assume this is a Coconut, as the symptoms are quite likely to come from a bad CPU to keyboard connection: contact strip failure or broken post are common sources for this sort of (somehow) weird behaviors.
Hope this helps.
Diego.
Edited: 2 Mar 2011, 2:41 a.m.
