Re: 41c repair Message #11 Posted by Andrés C. Rodríguez (Argentina) on 28 Feb 2011, 7:41 a.m., in response to message #9 by Paul Dale
This worked for me many years ago, but is up to you to see if it fits your case: Take a piece of thin two-conductor cable (the kind used for small headphones, or two lines of flat ribbon cable), and slip it from one side of the connecting block, setting it between the foam and the flexible circuit film. When in place, looking from a side, you would find (bottom to top): the main circuit board, the flex circuit film, the cable, the foam and the plastic block. The extra thickness will ensure good contact between the main circuit and the flex circuit. Of course, the cable serves no electrical function, and care should be taken to avoid any conductive thread protruding at the ends.
