Repairing an HP33E with springs Message #1 Posted by Alberto Fenini on 26 Feb 2011, 9:44 a.m.
Dear all,
I have had this 33E in a drawer for a while, with the usual corrosion problem. It also had some keyboard problems, and it
was purchased mainly to use the battery cover.
However, I wanted to give a try to an old idea.
I'll not write too much text, but I'm posting the sequence of images that led me to be able to use a battery pack again. I hope is going to be of help for anyone that has a similar problem.
Any suggestion, any comment,always welcomed !!
Enjoy the weekend, Alberto
Picture 1 - insertion of the springs, after the corroded parts have been removed
Picture 2 - view from behind, also a trace is missing, so that the cable will be soldered very close to the point where the external power supply goes
Picture 3 - springs soldered, and cutted on the back side
Picture 4 and 5 - pcb in place from diffeten views
Picture 6 - it works, in reality not all the keys are working, and since the power pcb is a slightly different version, there is no way to turn the unit off
Picture 7 and 8 - unit closed, it looks nice et voila, with the battery in place
Credits must be given to a on old post that was showing how to connect the power supply pcb to the pcb holding the battery terminals.
