HP Forum Archive 20
Hp-42s display problem
Message #1 Posted by aj04062 on 23 Feb 2011, 10:29 p.m.
I'm looking for confirmation on the root cause on a display failure on a 42 I just acquired.
Half of pixels in one ROW are out. Does it make sense that this would be a bad Zebra connection? Unless more drop out I think it might be foolish to open this up to repair.
Agree?
Thanks for the feedback!
Re: Hp-42s display problem
Message #2 Posted by Randy on 24 Feb 2011, 12:30 p.m.,
in response to message #1 by aj04062
Twisting the case slightly should prove/disprove the theory.
I have seen cracked LCD's along one corner, typically the top left or right that exhibit that behavior. The crack is not visible from the front, only from the back when the zebra is removed.
The missing row - which side and which row? From that I can figure out where that element terminates on the LCD.
Message #3 Posted by aj04062 on 24 Feb 2011, 9:34 p.m.,
in response to message #2 by Randy
Here is a picture
Message #4 Posted by Marcus von Cube, Germany on 25 Feb 2011, 2:20 a.m.,
in response to message #3 by aj04062
That's probably a failed driver IC.
Message #5 Posted by aj04062 on 25 Feb 2011, 7:01 a.m.,
in response to message #4 by Marcus von Cube, Germany
If that's the case, is a replacement only available from another 42 or is the 17BII have the same IC?
Message #6 Posted by Walter B on 25 Feb 2011, 8:36 a.m.,
in response to message #5 by aj04062
Please look at this:
IMHO there's not much on the pcb you can swap.
Message #7 Posted by Randy on 25 Feb 2011, 11:42 a.m.,
All 16 rows on the left side terminate along the top left edge of the LCD. The row in question would be right below the top right twist tab as seen from the back.
If it isn't a contact issue, it is either a failed driver row on the IC or a failed lead frame bond on the die. FWIW, I've found that mechanical failures of the lead frame out-number electrical die failures about ten to one. That said, that element lands pretty much dead center on the right edge of the die so I'd be inclined to think it is electrical, not mechanical.
Message #8 Posted by aj04062 on 26 Feb 2011, 10:03 p.m.,
in response to message #7 by Randy
Well, I pulled the calculator apart because as I twisted, another half row blinked on and off. I deduced, it was probably a bad connection in need of repair.
Well, I do believe it is. When I got it apart I immediately noticed green corrosion in areas near the zebra.
Well I cleaned as delicate as I could with warm water, vinegar and a q-tip. I think there are 2-3 traces that need repair. YES the corrosion is this bad, It reminds me of a 65 I repaired that had a completely exploded battery.
Anyone have a good source of VERY FINE trace repair? I think the conductive trace pen is the only way to go here, agreed?
Message #9 Posted by Wanderley Navarro on 27 Feb 2011, 12:06 a.m.,
in response to message #8 by aj04062
Maybe this will solve.
But an advise from Randy would be highly appreciated.
Message #10 Posted by aj04062 on 27 Feb 2011, 8:36 a.m.,
in response to message #9 by Wanderley Navarro
I Purchased a Micro Tip Silver Trace Pen last night from Cicuitworks. My only concern is that the tip may be too large to work with (.8mm)
The traces are about half that width I think.
I'll give it a try. I want to use it on the 65 with the exploded battery anyways.
