HP Forum Archive 20
SpeedUI 11.02 released
Message #1 Posted by Raymond Del Tondo on 17 Feb 2011, 7:12 p.m.
Hello all,
the new version 11.03 includes a minor display bug fix, and switches from the original VV GROB viewer
to the fast GROB scroller from Java. This saves nearly half a kilobyte;-)
Please see SpeedUI.pdf for details on how to invoke and use the fast GROB scroller.
Additionally, the documentation is in a process of getting streamlined, and moving from txt to PDF.
The new version is available here:
Walkthrough PDF
SpeedUI 11.03 zip archive
but _not_ on www.hpcalc.org (since the site has not been updated for 3 months now)
Have fun:-)
Raymond
[Edit: Link and text updated to 11.03]
Edited: 21 Feb 2011, 5:14 p.m. after one or more responses were posted
Re: SpeedUI 11.02 released
Message #2 Posted by Timo on 21 Feb 2011, 11:44 a.m.,
in response to message #1 by Raymond Del Tondo
Hi Raymond!
Thanks for your continued contribution to the HP-48G/GX software inventory. I actually have a question concerning the update from release 11.01 to 11.02. I've read the available documentation but I wasn't able to retrieve an answer from it.
I use a HP-48GX with SpeedUI 11.01 installed. I have all of the 11.01 libraries installed except the Input Form Builder.
My question is: Which specific libraries do I have to replace on my HP-48 and what would be the sequence to do it?
Thanks for your help in advance and best regrards, Timo
Message #3 Posted by Raymond Del Tondo on 21 Feb 2011, 5:11 p.m.,
in response to message #2 by Timo
Hi Timo,
generally I'd suggest to update all libraries to the newest revision.
However, I have just uploaded the SpeedUI 11.03 archive.
In this case only the files CF.LIB and UI.LIB have been changed, so these are the mandatory files to update.
I strongly suggest this important update, since the old 11.01 and first batch 11.02 contained a serious bug, which is fixed in 11.03 .
http://www.hpmuseum.org/guest/deltondo/sui_1103.zip
I have added a StartHere.pdf to the archive, which also contains an uninstallation paragraph.
Best Regards
Raymond
