min(a,b) and max(a,b) equation for HP-33S/HP-35S Message #1 Posted by x34 on 30 Jan 2011, 10:48 a.m.
HP-33s and HP-35s lack min and max functions. Yes, they could be easily programmed, but..
a) Label would be consumed on HP-33S (not a problem for HP-35S, thou)
b) You can't use conditionals in the Equation Writer
So, here is simple (but awkward) brute force implementation of MIN & MAX using Signum function, present on these calculators.
MIN(a,b)=((b-a)*SGN(a-b)+b+a)/2
MAX(a,b)=((a-b)*SGN(a-b)+b+a)/2
If used in program, they could be simplified by isolating (a-b).
