HP-25 displays "Error" when trying to input numbers Message #1 Posted by Harald on 22 Jan 2011, 5:44 p.m.
After several years of continuous use my HP 25 seems to have died today. I've used it on a daily basis and since it was connected to the power cord I very rarely turned it off in the last couple of years. But today it had a surprise in store for me. Everything seems to work fine. The stack works fine, I can add, multiply, divide,subtract and probably lots more. The only problem is, entering numbers is quite tricky :) As soon as I press any of the number keys it displays "Error". The shifted functions on those keys do the same. But I can input numbers by pressing "Sigma +" for example. And after entering them most calculations appear to work fine to.
When I switch to programing mode, it looks like there is something in the program memory that doesn't belong there.
I have tried swapping the keyboard, but that didn't change anything.
Any ideas on what happened here?
Harald
