Re: a challenge related to the 15 puzzle Message #1 Posted by Allen on 17 Jan 2011, 6:03 p.m.
Here's a quick RPL program based on the article you posted above. It uses a flag for parity tracking, and indrect addressing from the stack to scroll through the loops. Here are the program
41c
barcodes (including 2 programs to input 2 test matrices.)
Credit Note: Program was written using Free42, output to RAW and converted to barcodes using HP41UC program.
Inputs:
Register 00 - 1 (a pointer to first cell)
Register 01 - First number of grid
Register 15 - Last number of grid
Register 16 - 00 (assumes the space is in location 16)
Outputs:
Clear stack except for 1 in ST X if solution exists, 0 otherwise
00 { 53-Byte Prgm }
01>LBL "AQ"
02 CF 01 ' clears the parity flag
03 CLST ' clear stack
04 RCL 00 '
05>LBL 01 ' Loop for checking results
06 RCL IND ST X
07 X<0? ' Check the pointer to see if it's neg
08 GTO 02 ' if so, go to next loop
09 -1
10 STOŚ IND ST Z ' Otherwise negate and recall next value
11 RCL IND ST Z
12 +/-
13 GTO 01 ' repeat loop
14>LBL 02 ' Flip the parity flag- (starts even)
15 FS? 01
16 FC?C 01
17 SF 01
18>LBL 03 ' begin counting through the values
19 RCL IND 00
20 X=0? ' until you find a positive one to loop on
21 GTO 04 ' 00 value indicates end of matrix
22 X>0?
23 GTO 01 ' new loop found, go to main loop
24 ISG 00 ' increment reg 00 counter
25 CLX ' NOP
26 GTO 03 ' counter to check for the first pos. number
27>LBL 04 ' end program
28 CLST ' cleanup the stack
29 FS? 01
30 1 ' return parity based on Flag 1
31 END
Note: edited to add inputs/outputs section
Edited: 18 Jan 2011, 9:16 a.m.
