Running an HP7475A plotter on the HP-IL Loop Message #1 Posted by Richard L. Taylor on 11 Jan 2011, 10:14 p.m.
Hi; I am working on a computer project. It involves the Hewlett Packered HP41cx handheld computer. I would like to use my HP41CX to drive my HP7475A plotter that has an HP-IB interface. I have the following items:
1. HP41CX
2. HP 5061-5238 PLOTTER MODULE
3. HP 82160A HP-IL I/O MODULE
4. HP 82183A EXTENDED I/O MODULE
5. HP 82169A HP-IL / HP-IB INTERFACE UNIT
6. HP 9114B 3.5 INCH FLOPPY DRIVE
7. HP 82161A DIGITAL CASSETTE DRIVE WITH MINI CASSETTES
8. HP 82162A THERMAL PRINTER
9. A NUMBER OF HP-IL CABLES
10. HP 7475A PLOTTER WITH AN HPIB INTERFACE
11. L-com CMP SERIES - IEEE - 488 GPIB CABLE TO CONNECT THE PLOTTER TO THE HP-IL / HP-IB INTERFACE UNIT
The HP-IL loop works just fine with the floppy drive, cassette drive and the printer. I just can't get any response from the plotter. The plotter is on the end of the HP-IL loop
3.5 INCH FLOPPY DRIVE = HP-IL address 1
DIGITAL CASSETTE DRIVE = HP-IL address 2
THERMAL PRINTER = HP-IL address 3
HP-IL / HP-IB INTERFACE UNIT = (HP-IL ?) address 4 ---- Here I set the dip switches
PLOTTER = (HP-IL ?) address 5 ---- Here I set the dip switches
I have tried every thing that I can think of to get the plotter to responed to the HPGL commands sent through the HP41cx and no luck. I tried Sending the HPGL commands with or with out an ESC character (ascii no. 27) with the HP-IL command OUTA. Can any one help me with this? I would be very greatful.
