The HP71B Program That Caused Some Tech Queries Message #1 Posted by Namir on 29 Nov 2010, 6:29 p.m.
After all the discussions with my problems with the HP71B. Here is the program that solves the roots of a polynomial using the Abterth method. Edit the Data statements in lines 100, 120, and 170 to change the operational parameters and/or the polynomial coefficients.
10 REM POLYNOMIAL ROOTS USING ABERTH ALGORITHM BY NAMIR C SHAMMAS
20 REM NOVEMBER 30, 2010
30 OPTION BASE 0
40 DESTROY ALL
50 INTEGER M, N, I, J, K
60 COMPLEX X, P, D, S
70 DISP "REMINDER: DATA STMTS PROVIDE INPUT"
80 REM ===== START DATA INPUT SECTION ======
90 REM NEXT DATA IS MAX ITERS, TOLERANCE
100 DATA 100, 0.00001
110 REM NEXT DATA IS POLYNOMIAL ORDER
120 DATA 3
130 REM NEXT DATA IS SEQUENCE OF REAL PART, IMAGINARY PART OF
140 REM POLYNOMIAL COEFFICIENTS. START WITH COEFF. OF HIGHEST TERM
150 REM AND MOVE DOWN UNTIL YOU LIST CONSTANT TERM
160 REM DATA RLCOEF(N), IMCOEF(N), ... RLCOF(1), IMCOEF(1), RLCOEF(0), IMCOEF(0)
170 DATA 1, 0, 2, 0, 3, 0, 4, 0
180 REM ========= END INPUT SECTION ==========
190 READ M, T0, N
200 COMPLEX R(N),D1(N),C(N)
210 FOR I = N TO 0 STEP -1
220 READ X1,X2
230 C(I)=(X1,X2)
240 NEXT I
250 X = (0.4,0.9)
260 R(0)=(1,0)
270 FOR I = 1 TO N
280 R(I) = X*R(I-1)
290 NEXT I
300 FOR K = 1 TO M
310 FOR I = 1 TO N
320 CALL POLY(C(), N, R(I), P)
330 CALL DERIV(C(), N, R(I), D)
340 S = (0,0)
350 FOR J=1 TO N
360 IF I <> J THEN S = S + 1 / (R(I) - R(J))
370 NEXT J
380 D1(I) = 1 / (D / P - S)
390 R(I) = R(I) - D1(I)
400 NEXT I
410 REM TEST CONVERGENCE CRITERIA
420 C0 = 0
430 FOR I = 1 TO N
440 IF ABS(D1(I)) > T0 THEN C0 = 1
450 NEXT I
460 IF C0 = 0 THEN 'EXIT'
470 NEXT K
480 'EXIT':
490 FOR I = 1 TO N
500 DISP R(I)
510 PAUSE
520 NEXT I
530 END
540 SUB POLY(C(), N, X, S)
550 COMPLEX P
560 S = C(0)
570 P = X
580 FOR I = 1 TO N
590 S = S + C(I) * P
600 P = P * X
610 NEXT I
620 END SUB
630 SUB DERIV(C(), N, X, S)
640 COMPLEX P
650 S = C(1)
660 P = X
670 FOR I = 2 TO N
680 S = S + I * C(I) * P
690 P = P * X
700 NEXT I
710 END SUB
Enjoy!
Namir
Edited: 30 Nov 2010, 2:45 p.m. after one or more responses were posted
