Re: Physical dimensions of old HP calculators Message #5 Posted by Thomas Chrapkiewicz on 17 Nov 2010, 9:56 a.m., in response to message #3 by Gerson W. Barbosa
I too would be curious is there is more detailed information on the (previously)mentioned calculators such as:
Detailed thickness(es) - that is, for instance, the HP35s is 'wedge' shaped in that the display end is thicker than the keyboard bottom end (by about 0.8cm).
Also, location(s) of the keys - this in particular would be helpful in positioning a machine based - keypressing mechanism. I may optically scan in the machines and measure this.
TomC
