Re: Faceplate separation repair Message #2 Posted by geoff quickfall on 30 Oct 2010, 8:18 p.m., in response to message #1 by Jim Yohe
check out HPSolve, June 2010:
June 2010
The second half of the restoration article explains the faceplate removal and glueing procedure.
I suggest you remove the faceplate, depending on how much has separated, as that way you can put a reverse curve on it so that it glues back to the case with the corners down. If the raised edges are not to great then a fine paint brush and contact cement will work. Make sure to press the glue joint for a few minutes to ensure it does not raise.
Cheers, Geoff
