Re: [OT] New Casio Grapher Message #24 Posted by Ron Ross on 8 Oct 2010, 2:32 p.m., in response to message #23 by Tim Wessman
Along with the huge variable count of 28 variables ie single letter variables with theta and gamma or some such combination.
Truthfully, I feel that Hp SHOULD release an Hp 43s. A high end pocket calculator with I/O. Use the ROM of the Hp 50G, but gut the graphics (or include a VGA or DVI port as discussed later). Give it an okay LCD with 2-4 levels (with softkeys, just like the Hp 42s or 48G). Such a system would be able to use the huge library of existing 48G type programs if rewritten for the smaller screen.
Such a pocket calculator would be a great pocket companion for the technical field engineer. I/O could and should include an SD slot, usb slot and a small VGA or DVI type port so that graphics can be used by those that feel a need to have this capability. I feel it is a nice to have feature, but I have never used the graphics on my own Hp48g (but that could be because the Hp48G is notoriously slow to graph). Now, as a professional, I would never bother to use the graphics of a lowly calculator as I could use my PC to generate a better graph that could be printed out for reference too.
And Hp can't afford to go cheap on the keyboard. It has to be at the same standard or quality of the Voyagers or Pioneers.
Edited: 8 Oct 2010, 2:51 p.m.
