OT: HP200LX Mass Storage Message #1 Posted by Gerry Schultz on 6 Oct 2010, 1:47 p.m.
Hello All:
From a previous posting, I recently remembered that I had won a 1 MB HP200LX PDA at HHC2009. I've got a CR2032 backup battery in it now and, so far, it works great. I have an old PCMCIA 5-in-1 card reader that fits into the slot on the side and I put a 64 MB SD card in it. In the Setup application, it reports the card battery is okay (as far as I know the card reader has no battery in it.) From the Filer, under options, when I try to format the card, it requests that I want to format A and I say yes, it prompts for a new disk (I am assuming it's in DOS), press enter and it reports Format not supported on drive A:, Format terminated.
I believe the problem is the PCMCIA card I'm using with an SD card is not compatible with the 200LX. I have some Compact Flash memory but that doesn't fit the slot in the side. I have no manuals but I did find one on-line but it doesn't talk much about what kind of memory the 200LX requires that I could find.
So, my questions are, what hardware do I need to have a valid A drive, what is the largest size the 200LX will support, and I would like to be able to move the A drive memory card over to a PC to move files on and off the 200LX as Katie suggested previously so what's the best media type to use? Compact Flash? Using a PC application and a serial cable appears to be a real pain.
Thank you for your suggestions.
Gerry
