Re: Mini-Challenge: Zip Code Message #18 Posted by Thomas Klemm on 27 Sept 2010, 2:59 p.m., in response to message #1 by Thomas Klemm
The following challenge is based on an arithmetic problem I found in a mathematics book for elementary school.
I will add my solution for the HP-15C here within a couple of days.
Initialization:
10 STO 0
001 - 42,21,11 LBL A 022 - 30 -
002 - 32 0 GSB 0 023 - 9 9
003 - 32 0 GSB 0 024 - 0 0
004 - 32 0 GSB 0 025 - 20 ×
005 - 43,30, 7 TEST 7 026 - 34 x<>y
006 - 34 x<>y 027 - 43 33 R-^
007 - 33 R-v 028 - 30 -
008 - 43,30, 7 TEST 7 029 - 9 9
009 - 34 x<>y 030 - 9 9
010 - 33 R-v 031 - 9 9
011 - 43,30, 7 TEST 7 032 - 20 ×
012 - 34 x<>y 033 - 40 +
013 - 43 33 R-^ 034 - 43 32 RTN
014 - 43,30, 7 TEST 7 035 - 42,21, 0 LBL 0
015 - 34 x<>y 036 - 45,10, 0 RCL ÷ 0
016 - 43 33 R-^ 037 - 43 44 INT
017 - 43,30, 7 TEST 7 038 - 43 36 LASTx
018 - 34 x<>y 039 - 42 44 FRAC
019 - 33 R-v 040 - 45,20, 0 RCL × 0
020 - 43,30, 7 TEST 7 041 - 34 x<>y
021 - 34 x<>y 042 - 43 32 RTN
What is the behavior if you iterate this? Make a speculation.
Most numbers will end up with 6174. Only numbers composed of the same digit will end up with 0.
Try to proof your assumption.
My observation was the same as described in Mysterious number 6174. (cf. "Which way to 6174?")
So I guess I don't have to repeat that proof here. However I didn't ignore possible duplicates of the 55 numbers that remain after the first iteration.
Can your calculator be of any help?
Here's a small program that produces the 55 numbers left after the first iteration:
Initialization:
9 STO 1
EEX 3 / STO 2
043 - 42,21,12 LBL B 055 - 42, 6, 2 ISG 2
044 - 45 1 RCL 1 056 - 43 32 RTN
045 - 9 9 057 - 42, 5, 1 DSE 1
046 - 9 9 058 - 43 20 x=0
047 - 9 9 059 - 43 32 RTN
048 - 20 × 060 - 45 1 RCL 1
049 - 45 2 RCL 2 061 - 26 EEX
050 - 43 44 INT 062 - 3 3
051 - 9 9 063 - 10 ÷
052 - 0 0 064 - 44 2 STO 2
053 - 20 × 065 - 33 R-v
054 - 40 + 066 - 43 32 RTN
Now you can switch between the two programs A and B:
B: 8991
A: 8082
A: 8532
A: 6174
B: 9081
A: 9621
A: 8352
A: 6174
B: 0
A: 0
The data was then used to create this graph.
There's a direct proof in the same article as well. (cf. "Only 6174?")
Again the HP-15C can be used to solve the system of linear equations:
| 1 0 1 -1 | | a | | 10 |
| 1 1 -1 0 | | b | | 9 |
| 0 1 -1 -1 | | c | | 1 |
| 1 -1 0 -1 | | d | | 0 |
The solution is: [ a b c d ] = [ 7 6 4 1 ]
I must admit that I wasn't aware of Kaprekar's constant. I just saw this arithmetic problem in that book which made me wonder why. So thanks a lot to Paul Dale for pointing this out.
I know it wasn't a hard problem but still an occasion to use your best loved machines. Nevertheless I hope you enjoyed the contest.
Cheers and thanks for your contributions
PS: And where will all this lead us?
6174 Sörenberg
Edited: 27 Sept 2010, 3:43 p.m.
