Re: How to install/ru​n this program in an Hp 50g. Message #3 Posted by Daniel Oliva on 17 Aug 2010, 6:34 p.m., in response to message #1 by Vasheer
Move RLocus3.dir file to HOME using an SD card.
That is, using your PC, unzip the RLocus3.dir file to the SD card.
Then put the SD card on the 50g, hit L-Shift Apps to open the filer, go to the SD card, copy the RLocus3.dir file to HOME. Get out of the filer with ON, then press VAR and you'll see the program dir (RLOCU).
Press F1 to access the program dir.
