Identifying equations on HP 35s
Message #1 Posted by Richard S on 9 Aug 2010, 8:30 p.m.
Is there a way to add a title to the upper display register so it will show an easily identifiable title of the equation, while the lower display register will show the actual equation? I searched the Hp 35s manual but didnt see the answer to this question. Thanks for any help i may receive.
Richard
Re: Identifying equations on HP 35s
Message #2 Posted by Pablo P (Spain) on 10 Aug 2010, 5:10 a.m.,
in response to message #1 by Richard S
Hi Richard, yes you can do it. First add the equation in the list and then add a second equation just above the first one. The second equation will be the title that you can create usign the combination RCL + letter. You can compose any text.
For example, in the equation list you can create the next two equations. The first equation will be the "real" one and the second equation will be the title:
upper line: AREA CIRCLE        (PRESS: RCL + R/S, RCL + 7 ...)
lower line: PIxR^2
Edited: 10 Aug 2010, 5:10 a.m.
Message #3 Posted by Norman Dziedzic on 10 Aug 2010, 6:20 p.m.,
in response to message #2 by Pablo P (Spain)
That's brilliant! I was thinking this couldn't be done and I do have several equations that are similar looking which I'd like to distinguish.
Thanks!
Message #4 Posted by Vieira, Luiz C. (Brazil) on 10 Aug 2010, 11:56 p.m.,
Hi;
considering that the HP35S has memory enough to be used this way, I think this is worth doing. Also, HP33S users might take advantage over this tip.
Cheers.
Luiz (Brazil)
Message #5 Posted by Richard S on 10 Aug 2010, 8:01 p.m.,
Thanks for the help!!
