Re: Stupid question re HP-41 Sigma key... Message #2 Posted by Vieira, Luiz C. (Brazil) on 19 July 2010, 11:15 a.m., in response to message #1 by Jim L (OHIO)
Hi;
if you are referring to the Greek letter SIGMA (cannot add it with current character set) it is available with [shift][F] while in ALPHA mode. In PRGM or RUN mode, [shift][F] performs [CLSIGMA] (clears statistical registers contents). Look at the back of your HP41, right below the battery compartment, and you'll see a drawing of the keyboard in ALPHA mode. You´ll find these symbols there.
BTW, there is no such thing as a stupid question once you do not know the answer...
Cheers.
Luiz (Brazil)
Edited: 19 July 2010, 11:23 a.m.
