Re: HP-35 Manuals Message #9 Posted by tim m. on 16 July 2010, 1:49 a.m., in response to message #1 by aj04062
My manual is identical to yours. I purchased it along with an HP-35, charger, hard case, leather case, receipts, repair slips, and personal correspondence--all from the original owner. My '35 is an early version 2 (no "35" on the front label, no red dot, raised bump on the "5" key, serial number label between the two bottom feet). It originally had the infamous bug, but was repaired and so has a newer "HP-35" back instruction label. The calculator has a serial number of 1143A 31237.
Hope that helps,
Tim
