Re: HP-41CX halfnut speedup Message #4 Posted by Diego Diaz on 11 July 2010, 12:27 a.m., in response to message #3 by Theo Kas (Australia)
Hi Theo,
I am assuming that any mod to increase the speed would have to be done to this small PCB....?????
Nope! The LC resonant circuit in on the keyboard PCB.
The main question you'll have to answer is if you want a "permanent" speed-up or a "switchable" one.
In the firt case just replace the SMD capacitor between pins 9 and 10 of the CPU (just under key [5]) with one in the range 22pF to 47pF (depending on how much "thrust" you want to make your 41 run at)
The second case is somehow more complicated since you'll need a suitable means to turn the "turbo" mod ON and OFF; and involves some type of switch and cabling for the task and, eventually, some case mods (filing, drilling, etc.) to gain acces to the switch.
Wish you the best of lucks with your project.
Cheers from Spain.
Diego.
PD. Not intended to refrain your enthusiasm, but IMHO 41's were not "born to run" (even at 4x they're still pretty slow). As I said, just my opinion.
