Re: DIM LCD HP-11 Message #3 Posted by aj04062 on 3 July 2010, 10:30 a.m., in response to message #2 by Randy
using a stopwatch it took about 13.5 seconds for the display to read all 8's.
Does this mean the clock is too fast. Does too fast result in a dim lcd or the other way around?
BTW, I ran the same test on my 12C and it finished about the same time. It's display is fine. (SN MY81707265)
I have a donor 12C from singapore (SN 3519S05250) which is built with the same 1 pc board. I want to determine if I can fix this with caps or if I should tear into it to replace the LCD. I prefer to do this as a last resort but will do so if it is the cause.
Thanks,
Adam
Edited: 3 July 2010, 10:46 a.m.
