Re: 97 printer paper not advancing Message #6 Posted by Keith Beyer on 6 July 2010, 8:06 p.m., in response to message #5 by Klaus
Thanks for the posts. I followed the procedure I found in Archive 15:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv015.cgi?read=89643
Basically, I cut a narrow (about 3 mm) and long (a few inches) piece of 600 grit sandpaper. I fed it through with the grit facing the roller (grit toward the front of the calc) and pressed the paper advance as I alternately held the tail of the piece of sandpaper and released it. This way it would scrape the roller and advance alternately. It took multiple passes on each roller, but now the paper is advancing as it should!
Thanks to those who posted and thanks to the original posts in the archive - and the Museum for maintaining the archive to begin with!!
