Re: pleas help me to send "txt" file to 48sx by usb irda from the computer Message #2 Posted by Vieira, Luiz C. (Brazil) on 28 May 2010, 10:24 a.m., in response to message #1 by samiroch
Hi;
just to make sure: based on your post, your computer does not have a serial, RS232 compatible port, is that correct? If not, you will need a USB/RS232 converter/translator because the HP48SX offers only a RS232 compatible I/O port. Also the HP48SX IR protocol is different of the IRDA (the HP50G is IRDA compatible, IIRC). I am not sure if your IRDA computer port can be configured to communicate with the HP48SX.
Success! And sorry not helping the way you need, though.
Luiz (Brazil)
