Re: 1972 HP-35 With Bug Message #2 Posted by Ignazio Cara (Italy) on 15 May 2010, 2:57 a.m., in response to message #1 by aj04062
congrats for your new calculator, and yes, is safe to connect the two extreme pin to verify if the calculator works with the battery pack inserted. But if you want replace or clean the original jump, you must open the body removing, even partially, the rear label.
HTH
Ignazio
