Re: Jazz 50G Message #3 Posted by Han on 13 May 2010, 1:22 a.m., in response to message #2 by Martin Pinckney
Han, I was not familiar with Jazz, so my curiosity was piqued. I gather that it is a 48 program that compiles System RPL into ML, right? So my question to you or anyone else, does the version on hpcalc.org run on a 48sx? Does it work with User RPL (which is supposed to be a subset of System RPL)?
It compiles System RPL source code (written in the form of a "string") as well as machine code (using HP mnemonics). Personally, I have always preferred HP mnemonics (more readable, easier to add comments) so I never got into MASD (the built-in compiler for the HP50G). Hence the port.
Jazz is also capable of editing User RPL programs, but you should probably use TED to do your editing (as opposed to ED, both of which are part of Jazz). Other features include disassembler, System RPL debugger, and machine code debugger.
The one on hpcalc.org (under the HP48 section) does indeed run on the HP48SX (as well as the HP48GX). It also runs on the HP48G+ or any HP48 with upgraded RAM.
