Re: Repairing a HP41 Printer? Message #3 Posted by Vieira, Luiz C. (Brazil) on 27 Apr 2010, 2:57 p.m., in response to message #1 by Dimitri Simitas
Hi;
there are two small springs, in both left and right tips of the cog that pulls the paper, that control the pressure made over the printed paper. Are they in place? Also the rubber-like (kind of a polymer) rings in the same cog may be either contaminated (dirty) or wear. Should check it.
I also have a printer that does not pull the paper because the rubber belt that connects the motor pulley to the cog mentioned above is loose and it slips.
Cheers.
Luiz (Brazil)
