Re: Rebuilding an HP 41 battery pack Message #6 Posted by John Robinson on 20 Apr 2010, 6:42 p.m., in response to message #1 by DavidShenk
Hi David, I am in the same situation, and I thought about springs, but ruled them out, as I doubt they would stay in place. I am going to try some thin "spring steel" shaped pretty much to the same shape as the originals. I'll let you know how I go, if it works, I can send you some of the same steel - I have enough to build 100s of 82120 :-)
Cheers,
