Calculator like HP10BII but scientific and RPN
Message #1 Posted by Gerardo Rincon on 14 Apr 2010, 6:23 p.m.
I really like the simplicity of the HP 10BII - it is great for work. I wish there was the option to use it in RPN mode (it already has an Input Key that maybe could have worked as an Enter Key as well). The keyboard feel of the 10BII is very nice as well.
It would also be great if there was a Scientific Calculator simple like the 10BII with some stats and RPN.
Re: Calculator like HP10BII but scientific and RPN
Message #2 Posted by Dave Johnson on 14 Apr 2010, 6:59 p.m.,
in response to message #1 by Gerardo Rincon
Hey..Please don't give HP ideas like this.....The HP10BII will not function for more than a few months (display stops functioning, keys get mushy and not responsive) I have experienced this with several... Try to 35S....
Message #3 Posted by Gene Wright on 14 Apr 2010, 10:48 p.m.,
in response to message #2 by Dave Johnson
Hey Dave.
Which version of the 10b2 are you referring to? The one done out of Australia or the new industrial design launched about a year and a half ago?
The earlier one really is / was a mess. The new industrial design has been rock solid for me. I've banged on it over and over again and never had any problems at all.
By contrast, the ACO version of the 10b2 was junk a week after I got one.
So... which have you had a problem with? If the new ID, then that's news to me! :-)
Message #4 Posted by DaveJ on 15 Apr 2010, 2:03 a.m.,
in response to message #3 by Gene Wright
Ok, my ears just pricked up. Some aspect of the 10BII design came out of Australia??
Dave.
Message #5 Posted by Paul Dale on 15 Apr 2010, 2:22 a.m.,
in response to message #4 by DaveJ
HP's calculator group was based in Melbourne for a few years. They closed down about 8 years ago from memory.
I was contracted to do a network bootloader for them for a never realised device running uClinux. I think I've still got the box of prototypes and development boards something.
- Pauli
Message #6 Posted by DaveJ on 15 Apr 2010, 2:35 a.m.,
in response to message #5 by Paul Dale
Yes, I know that much, I actually applied for an advertised calculator design job there at one stage! They closed shop about 6 months later IIRC.
The 10BII is that old? (I'm not into financial calcs so haven't a clue)
Dave.
Message #7 Posted by Bart (UK) on 15 Apr 2010, 4:15 a.m.,
I have a new version 10Bii and it feels quite solid.
Message #8 Posted by Dave Johnson on 15 Apr 2010, 7:37 a.m.,
The 10BII I had issues with was a few years ago and not the most recent one so I hope they have improved it but once I've been burned I don't recommend items!
Message #9 Posted by Gene Wright on 15 Apr 2010, 7:47 a.m.,
in response to message #8 by Dave Johnson
Ah, then you should try again.
The ACO version of the HP 10BII was a truly awful design. Think 49g with its rubber keys vs. what the 50g is today.... the 50g is MUCH much better and nothing like the rubber key monster.
You can find a current industrial design HP 10BII on ebay for $15 or less.
Message #10 Posted by Bart (UK) on 15 Apr 2010, 8:07 a.m.,
in response to message #9 by Gene Wright
Yep, I got mine for £5. Only has very minor scratch on the metal above the screen.
Message #11 Posted by Katie Wasserman on 14 Apr 2010, 7:22 p.m.,
The new 30b has nice "clicky" keys, great stats and RPN (and programmablility and trig functions). You can customize the keyboard to a limited extent and it's just slightly larger than the 10bii.
Most of the functions that you don't want are hidden in menus so if you ignore them you'll have a simple calculator.
-Katie
Message #12 Posted by Gerardo Rincon on 14 Apr 2010, 7:43 p.m.,
in response to message #11 by Katie Wasserman
On simple thing I don't like about the 30B or 20B is that the % change is not available in a top key. It is buried in menus and take and bunch of key strokes just to do a % change. In general I really like the 30B. I hate the keyboard of the 20B. I like the "look" of the 20B
Edited: 14 Apr 2010, 7:45 p.m.
Message #13 Posted by Bruce Bergman on 14 Apr 2010, 7:51 p.m.,
in response to message #12 by Gerardo Rincon
You can reassign the "%" to any key you like. Easy peasy.
Get the 30b -- it's amazing.
Thanks, bruce
Message #14 Posted by Gerardo Rincon on 14 Apr 2010, 8:03 p.m.,
in response to message #13 by Bruce Bergman
can I assign the % change? how you do that? I am not a programer.. How would I enter both values to get the % change?
Message #15 Posted by Howard Lazerson on 14 Apr 2010, 9:38 p.m.,
in response to message #14 by Gerardo Rincon
Where to buy ??? amazon and hp store dont have the 30b, thanks, Howard
Message #16 Posted by Katie Wasserman on 14 Apr 2010, 10:53 p.m.,
%-change is really an interactive menu on the 30b. If you want the good old RPN way of doing it you need to write a little program and assign that program to the '%' key.
I do this (assuming you're in RPN mode)
Enter program mode by pressing SHIFT Keypad. Choose a program slot (0 is the default) and press INPUT. Then enter the following steps. (You'll need to press the up arrow to get to line 0.)
0  %       ; line zero is the (optional) key assignment location
1  ) Swap  ; this is just swap but shows the ')' too
2  -
3  ANS      ; same as LASTx in RPN mode
4  /
5  1
6  0
7  0
8  x
9  Stop     ; (This is SHIFT-HOLD RCL)
Press SHIFT Keypad again and you'll see: 10.126 (10 bytes used, checksum = 126)
Use the above program like you would %-change on most HP RPN calculators:
4 INPUT 5 %
and you'll see: 25
-Katie
Edited: 14 Apr 2010, 11:00 p.m.
Message #17 Posted by Gene Wright on 14 Apr 2010, 10:58 p.m.,
In RPN mode, you would enter both numbers and then execute the program that is assigned to the key you want to execute the % change function.
Suppose you want it to be shift-hold 1 --- you don't plan to use RAND very much. If you want to replace NPV, then press NPV when step 0 is showing and you would then start the program when you press the NPV key.
Program:
001 ) SWAP
002 -
003 shift ANS
004 /
005 1
006 0
007 0
008 x
009 STOP
now press down down up so that step 001 is showing.
press shift and hold it and press 1. SH1 shows up on line 0 of the program.
The program takes 10 bytes.
In run mode, key 30 = 25 = then shift hold 1. The answer of -16.67 is shown in the display. % change is 16.67% down.
Message #18 Posted by Gene Wright on 14 Apr 2010, 10:58 p.m.,
in response to message #17 by Gene Wright
Heheh. Katie beat me to it. Good to see our programs are the same. ;-)
Message #19 Posted by Katie Wasserman on 14 Apr 2010, 11:01 p.m.,
in response to message #18 by Gene Wright
That's the problem with this forum, everyone is so damn responsive we duplicate each others work.
-Katie
Message #20 Posted by Gene Wright on 14 Apr 2010, 11:05 p.m.,
in response to message #19 by Katie Wasserman
-Gene
Message #21 Posted by Tim Wessman on 14 Apr 2010, 11:14 p.m.,
in response to message #20 by Gene Wright
Whoa, Magic!
TW
Message #22 Posted by Gerardo Rincon on 15 Apr 2010, 6:48 p.m.,
Katie and Gene,
I just have to say again: thank you for the program you wrote for me - It's awesome! I use it all the time.
mac
Message #23 Posted by Gerardo Rincon on 15 Apr 2010, 8:14 a.m.,
Katie and Gene,
Thank you so much fo the explanation! It works!
One more question: will this program ever be earse (by itself) I know I can use the reset button and erase Program 0. If I have to replace the batteries, would it erase?
Edited: 15 Apr 2010, 8:18 a.m.
Message #24 Posted by Gene Wright on 15 Apr 2010, 8:27 a.m.,
in response to message #23 by Gerardo Rincon
Katie will probably have answered this before I click "I agree. Post Now" but here goes.
It should not erase if you replace the batteries one at a time. If you remove BOTH batteries before replacing either, then all bets are off.
You can learn a great deal about programming the HP 30b by going here:
HP 30b learning module material
The last 6 on the list include programming related material.
Message #25 Posted by Gerardo Rincon on 15 Apr 2010, 1:24 p.m.,
in response to message #24 by Gene Wright
Great information!
