Re: Note for NoV-64 users. Message #5 Posted by Diego Diaz on 16 Apr 2010, 2:34 a.m., in response to message #4 by Eric Smith
Hi Eric,
You're more than probably right... as the "family" is growing up, its different members' features may lead to confusion.
Here you are an abstract:
Clonix-41:
It's basically a ROM-box which can hold up to 6 pages (4K each)
Intended to "clone" any ROM PAC module(s).
Clonix-D:
Same features that Clonix-41 but double ROM size. Its ROM is divided in two blocks of 6 pages each. These blocks can be swapped by plugging the module into an even or odd port.
NoVRAM:
A RAM-Box, mainly intended to clone "Adv HEPAX". It has 16K RAM and ROM to hold the four pages of the HEPAX module plus two extra ROM pages.
NoV-32:
Same as NoVRAM but double RAM size. Its 32K RAM are organized in two blocks of 4 pages each which can be swapped by writting h'000 or h'001 into a control word placed at address H'4100.
NoV-64:
Again HEPAX emulation with 4 blocks of 16K ram (thus the "64") and another two blocks of 16K ROM. Switching between the blocks can also be achieved by writing said control word.
Alternatively a new ROM (ICEBOX1H) written by Geir Isene, includes several commands in order to handle the ROM and RAM blocks of a NoV-64, allowing the user to switch between them from a FOCAL program.
NoV-32 is backward compatible with NoVRAM and Clonix-41, as NoVRAM is backwards compatible with Clonix-41.
NoV-64 is compatible with Clonix-D in terms of internal functionality, but it lacks the possibility of swapping its ROM blocks by changing the port. That's why it only shows 6 pages and they must be programmed in both banks.
Hope this clarifies a bit the differences.
Cheers.
Diego.
Edited: 16 Apr 2010, 2:40 a.m.
