Re: HP 48gII displays division as a fraction Message #5 Posted by Tim Wessman on 10 Apr 2010, 10:14 a.m., in response to message #4 by David Hayden
It isn't perfect, but it was written from the approach of "lets teach you about the most common stumbling blocks, while introducing some of the really neat things this calculator does. By the time you go through it, you should be able to use it for day to day calculations without problems and at least have an idea where to go if things go wrong."
http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1414559
Click on the paperclip on the second post there. It was the first placeI could findit.
I'd download it and tell your friend to go through it. If I recall, it talks about real/approximate atleast 3 places. Don't you lovecomputers with broken keyboards. . . (using the wife'smachine that is full of food under the keys :-D )
TW
