Re: 41C - Curve Fitting Revisited Message #4 Posted by Geir Isene on 7 Apr 2010, 11:52 a.m., in response to message #3 by 聲gel Martin
Thanks for the explanation regarding the conflicting use of the c-register. It clears up this issue for me. I prefer the CCD over the AECrom - although I really needed the curve-fit program, hence the long FOCAL program. Having it as part of a non-conflicting MCODE module would be the best.
The FOCAL program covers several needs:
1. Curve fitting with a large range of curves
2. Basic statistics
3. Advanced statistics such as Momentums/Skewness/Kurtosis
4. The ability to use a data set from XM and analyze it through #1-#3 above (both single and paired data points).
If we could produce a new STAT module that covers the above needs and others (ANOVA etc.) - with saved data sets (XM, cards or mass storage) I would be in heaven.
Edited: 7 Apr 2010, 12:19 p.m.
