Re: HP 32SII keyboard - dead column of keys fixed Message #3 Posted by geoff quickfall on 27 Mar 2010, 2:34 a.m., in response to message #2 by DavidShenk
problem is, it isn't the twist tabs that are responsible. It is the foam pad used to push the keyboard flex PCB against the logic PCA.
This foam deteriorates with time and loses its resiliency.
Although the fix works for now the foam will need to be replaced.
Cheers, Geoff
