Query re. HP 82973A HP-IL Interface card and 82161A Digital Cassette Drive Message #1 Posted by John AS (UK) on 10 Mar 2010, 8:00 a.m.
I'm currently reading the manual for the 82973A HP-IL Interface card (ISA bus card), it describes the HPIL.SYS driver as follows:
In CONFIG.SYS enter the line:
DEVICE = HPIL.SYS
You can use HP-IL peripherals as you would other devices connected to your
IBM PC computer. The following table lists the names that your IBM PC
recognizes and their corresponding devices on the loop.
Name Device
HPILPRN The first printer on HP-IL.
HPILPLT HP 7470A Graphics Plotter (option 003).
Drives C to J (D to K) Disc drives or HP 82161A Digital Cassette
Drive. (Drives D to K for the IBM XT.)
I can understand that a 9114A/B disk drive would appear as a MSDOS drive letter, and the manual says these can either be formatted by an HP-110 or by usng the HPILFOR utility on a PC with the 82973A. But can you actually format a cassette tape as an MSDOS drive (ie with a FAT), either on an HP-110 or via the 82973A?
I thought from earlier forum posts that the 82161A only understood Filbert protocol, and the HP-110 only understood SS-80 protocol, so the two were incompatible (without any additional software!) I would also be surprised if HPIL.SYS provides support for the Filbert protocol.
