HP-41 / EMU41P emulator query Message #1 Posted by John AS (UK) on 3 Mar 2010, 5:55 a.m.
I have recently installed the free version of EMU41P (HP-41 emulator) on my HP Portable Plus (has 1MB RAM so should work fine).
I am having problems with ALPHA mode, I am seeing the following:
Key pressed -> Character displayed
A -> a
B -> b
C -> c
Q -> *
W -> *
N -> *
T -> *
H -> *
basically I can only enter lower case abcd, other characters give * (I did see some other special characters, can't remember what I pressed), I can't enter upper case A to Z. I think I have entered some sort of character mode, can anyone suggest how to return to normal? Backspace deletes the * characters as normal.
I can enter commands OK, eg
XEQ ALPHA CAT ALPHA
enters the CAT command.
