HP-41: Read/Write XM file from a LIF-file? Message #1 Posted by Geir Isene on 1 Mar 2010, 6:38 a.m.
What is the easiest way to both read & write an XM-file to a LIF file. I believe I could read the file via Tony Duell's lifget... but write?
Edit: Turns out even reading an XM file from a LIF-file is quite a task - first saving all of Extended Memory to a LIF-file via WRTXM (from Extended IL(+)) and then extracting the whole XM file via Lifutil's command "lifget -f 'lif-file' 'xm-file'" and then poking out the file within Extended Memory from that... tough.
Anyone got some magic up their sleeves?
I will pay you back with a severe geek-hack :-)
Edited: 1 Mar 2010, 3:38 p.m.
