Re: 48G keyboard weirdness Message #4 Posted by Vieira, Luiz C. (Brazil) on 9 Jan 2010, 8:17 a.m., in response to message #3 by Lincoln
Hi, Lincoln;
because the key has a 'motion irregularity', it seems to me it is a mechanical problem. The delayed activation may also be related to this as well.
Anyway, to remove any chance of software causes, can you save all of your data and clear calculator memory? You can also hardware reset the calculator by using the small hole in the back of it. Then you can try the key again and see what happens.
Not too much of a help, I know...
Success!
Luiz (Brazil)
Edited: 9 Jan 2010, 8:18 a.m.
