Works with MLDL2000: config listed Message #4 Posted by Vieira, Luiz C. (Brazil) on 2 Jan 2010, 1:00 a.m., in response to message #1 by Geir Isene
Hi, Geir;
I loaded the ICEBOX1G.ROM (MLDL2018A, firmware updated) and it listed OK in the HP41. The ROM mapping is like this:
Page# image
5 HEPAX 1D (4 banks)
8 SRAM (dir empty)
9 SRAM (dir empty)
A Advantage 1D (bank #1
B Advantage 1D (banks #1 & #2)
C CCD OSX
D ICEBOX 1G
E DAVID ASSM
F MNFR LBLS (David Assembler labels) The ICEBOX 1G appears accordingly and its functions are listed as well. Because I prefer the block catalog feature, I usually leave regular CCD or the reduced CCD-OSX configured somewhere, and in this particular case, ICEBOX 1G header and its functions show perfectly well.
I tested just two functions for functionality and both worked fine: BLNG? and KALNG?. In time: BLNG? emits a very brief tone that can be suppressed with CF 26. Is it normal? There is no mention to such tone in the manual.
Again, I do not own a NoV64, but I'd ask you to confirm if the NoV64 accepts a functionality available with MLDL2000 configuration: to enable or disable a particular image. Again, I do not know if it is possible in the NoV64.
Hope this helps.
Cheers.
Luiz
Edited: 2 Jan 2010, 1:01 a.m.
