Re: Broken Rom/Ram switch on RAMCARD Message #5 Posted by Han on 8 Dec 2009, 4:38 p.m., in response to message #4 by Bill Platt
Bill,
Stuff you may already know:
Looks like a surface-mount toggle or switch. I do not know if there are standard packagings, or if that particular component is still even manufactured. I will see if I can dig up any Klotz cards I own and check if there is any packaging markings on the toggle. Do you still have the original toggle? It may indicate what type of packaging it is.
Worst case scenario is that you will have a RAM card that cannot be write-protected as long as you make sure to resolder the circuit for RAM mode.
