Deoxit: now that I have it, how do I use it? Message #1 Posted by Michael Meyer on 1 Dec 2009, 6:31 p.m.
I just got a bottle of Deoxit D100L (100% solution). I also picked up some small syringes, so I can drop small amounts on pinpoint areas.
Let's say that I drop a small amount into an HP-25 keyboard hole for a misbehaving key. Do I need to rinse the stuff out, or is it safe to just drip a tiny bit into the holes?
If I clean a whole circuit board, what is the best way to do this? (The stuff is so expensive). I was thinking about using a zip-lock bag (not supposed to hurt plastic) so that I can re-use the bag to clean many boards.
If I choose to dilute the solution, what solvent should I use-- just water?
Thanks... I couldn't find the answers to this, even on the Deoxit site and forum.
